Multifunction DAQ
cDAQ-9172 hardware driver issue
Hello All,
I am currently using cDAQ-9172 chassis with NI 9401 module to do a project. However, I stumbled upon an issue with the device driver. I have the appropriate compatibility between OS, Labview 16 (32bit) and NI DAQmx driver 17.5. NI MAX was able to detect the chassis but it's not in the proper Data Acquisition Device symbol, just the usb symbol instead and no modules detected. Device Manager shows the device with error code 37 (Device driver was not able to be initialized. Device driver could not be loaded, error status is 0x%x.
Any help or insight is appreciated. Kudos.
(1,043 Views)
Dear szekeat,
Have you tried repairing your driver from NI package manager?
It should help.
best,
anasei.
(877 Views)
