05-08-2014 08:34 AM
I'm new to the forums, so forgive me if this has been answered already.
Im using the c-DAQ 9172 chassis with a 9221 Analog input module. I want to read three transducers in real time. The problem i have is two if the transducers are 7.5K psi rated and one is 100 psi rated, making me use two diferent scales. I can do N channels on the reading of the system but will only allow me to read the two 7.5 K transducers. I dont use DAQ assistant, I create a virtual channel and add all of the components to read from the module. When I create a different instance for the third transducer, it gives me the error: Error 201003, module is already reserved. I need some help please. Let me know of another way to accomplish what im trying to do. I have used the DAQ assistant, but the data is incorrent on the 100 psi transducer, which is why i manually create the virtual channel.
05-08-2014 08:44 AM
05-08-2014 08:50 AM
Can you explain "Each ocnnected to the next"? And are you referring to the Create Virtual Channel.vi?
05-08-2014 09:14 AM
05-08-2014 10:44 AM
I got it working, Thanks Dennis!!
