09-04-2008 03:35 PM
I am using the NI 6009 USB board. I have a module that produces two puls Ao0 and Ao1. I also tie Ao0 to the freqency input to get an accurate cout pf pulses. I have a second VI that monitors temperature and pressure at the same time. I have an internal clock on this VI. How can I sample the data at 9 second on time and 9 second off times?Then write to a file with a real time?. This is based on a 9 second pulse ON and OFF for 9 seconds.
Philip
09-05-2008 03:47 PM
Kent
Applications Engineer
