how do i deal while acquiring data rising ni9237
Hi everybody,
I created under matlab a code that acquire data from four gauges fixed to a beam using NI9237, the aim of my code is to estimate the applied force to the beam, my problem is that at the in the end of acquisition i get the expected force devided by 10(7000N rather than 70000), i am pretty sure that the problem comes form the NIdevice, does any one of you have a suggestion?
Yours Faithfully.
(4,094 Views)
Hello ismailel,
You can test your device using NI MAX by following this tutorial:
http://www.ni.com/tutorial/4638/en/
Last version of MAX:
http://www.ni.com/download/ni-system-configuration-14.5.0/5158/en/
Jovan N. - Application Engineering
(4,041 Views)
Thank you for your reply, what i've done is i that i created a task to calibrate the channels and the results were good but now that it's done i need to know how to apply this calibrations in real channels  so i can get data corectly???
(4,010 Views)
