Multifunction DAQ
installing daqmx
I am using Windows 8, installed Labview 2014 Student Edition, then downloaded NI-DAQmx, however do not have any icons I expected to see in a YouTube video.  My question is, how/where to obtain the respective DAQmx sub-icons?
Message 1 of 10
(5,969 Views)
What version of DAQmx did you install?  Did you install DAQmx AFTER installing LabVIEW?  Did you reboot your computer?
GCentral
Message 2 of 10
(5,961 Views)
I installed DAQ version VDM 2013, and yes, I installed DAQ after installing Labview then rebooted computer.
Message 3 of 10
(5,957 Views)
There is no such version 2013. I have no idea what VDM is. You should install the latest to get support for LabVIEW 2014 - http://www.ni.com/download/ni-daqmx-14.5.1/5271/en/
Message 4 of 10
(5,948 Views)
I used the hot link and downloaded the most recent version of DAQmx as suggested, restarted both the computer & Labview, and the "Vision & Motion" shows up s before on my "Functions Pallete" of the "Block Diagram" window, however no icon are present when I select "Vision & Motion". Other thoughts or suggestions?
Message 5 of 10
(5,938 Views)
I think I am trying to get the correct module to work.  My objective is to convert the pixel RGB values of a camera's image file to CieLab color space coordinates, then obtain the mean, mode, std_dev, and a histogram of the each the three data sets.  I found a link on the NI website indicating the IMAQ Color Processing Pallete has a function (i.e., Vision & Motion ->Color Processing -> ColorHistogram) that may very well do what I'm trying to achieve, but it indicates the NI Vision Development Module is required.
Thanks for the input,
Message 6 of 10
(5,936 Views)
Please note, I have the "Student Edition" and not the "Student Edition Suite".
Message 7 of 10
(5,929 Views)
The vision functions have absolutely nothing to do with DAQmx.
So VDM stands for Vision Development Module? Why would you install a 2013 version when using 2014 LabVIEW?
Try http://search.ni.com/nisearch/app/main/p/ap/tech/lang/en/pg/1/sn/n8:13,ssnav:ndr/
Message 8 of 10
(5,920 Views)
Accepted by jwtrexler
Thank you for the assistance with respect to the "Vision and Motion", the link to the lastest version works as you suggested.
Message 9 of 10
(5,910 Views)
Then you should mark my answer as the solution - not your thank you. Click on Options to change it.
Message 10 of 10
(5,903 Views)
