06-16-2011 12:47 PM
I recently installed nidaqmxbase 3.4 on CentOS 5.4 with an NI USB-6009. Whenever I attempt to run any of binaries compiled via gcc from the /usr/local/natinst/nidaqmxbase/examples folder I run into the following message
LabView caught fatal signal
10.0 - Received SIGSEGV
Reason: invalid permissions for mapped object
Attempt to reference address: 0x0x8c95e8c
Segmentation fault
From commenting out code blocks I have found that this error occurs at the line
DAQmxErrChk (DAQmxBaseCreateTask("",&taskHandle));
which is line 67 in examples/ai/acquire1Scan.c for example.
Furthermore most of the binaries that have to interface with the usb-6009 such as FWUpdate give me the same error.
If anyone has any ideas on what's going on I'd really like to hear them.
-Aaron
06-19-2011 10:23 PM
Hello Aaron,
Do you have any other device that you can test DAQmx example code with? The reason why I ask, is because if other devices are giving you same errors, then the drivers may not be installed properly. Also, CentOS is not one of the listed compatible OS's for NI-DAQmx Base 3.4. Even though CentOS is 100% compatible with Red Hat, not all versions of Red Hat can use NI-DAQmx Base 3.4. Is it possible for you to try openSUSE 11.1 or 11.2?
Best Regards,
Jignesh P
03-21-2012 05:23 AM
Did you find the solution ? I get the same error (using Centos 5.6)
Amicalement,
Francois
03-22-2012 01:17 PM
Hi Francois,
Have you checked the recommendations in the post above? Also, this link may be helpful. Unfortunately, CentOS is not supported under the DAQmx driver.
04-07-2014 07:46 AM - edited 04-07-2014 07:48 AM
I know this is a 2-year-old thread, but since some people still may be searching for posts on this issue (as we have been) I thought I would throw out some ideas on how we solved it in CentOS 6.4. (By "we" I mean two of my colleagues who are Linux experts -- the credit goes to Hank and Liza, not me ! ) The LabVIEW development environment had no problems; it was when we build applications (with App Builder) and tried to run them that we got the error message below. And this was only visible when running from a terminal window; nothing happened at all when running by double-clicking on the application icon.
LabVIEW caught fatal signal
10.0.1 - Received SIGSEGV
Reason: address not mapped to object
Attempt to reference address: 0x........
Here is what we did:
1 .. Provide boot option to limit the memory to 4 GB. As "root", we modified the "title" line in /boot/grub/grub.conf as follows:
title CentOS (2.6...) memmap=60G$0x100000000 LabVIEW
2 .. We have a newer version of the gcc compiler, so prior to installation of LabVIEW, we ensured that gcc pointed to "/usr/bin/gcc" rather than the newer "/usr/local/gcc-4.8.1-bin/gcc".
3 .. Disable Security Enhanced Linux. This is done by editing (as "root") the /etc/selinux/config file and adding or modifying the "SELINUX" line to be:
SELINUX=disabled
With these modifications, we can now run applications on CentOS 6.4. For those folks having these issues, any or all of these fixes may be worth trying. Good luck !
-John
