04-17-2016 07:26 PM
04-17-2016 07:38 PM
Wait...I figured it out. The ground at the end of the circuit messed everything up. These are voltage output and input that I got. I'm not sure how I'm suppossed to change the argument of the AC source voltage.
04-18-2016 03:52 PM
It would seem that the argument that you have to change of the AC power source would simply be the phase of the source. What exactly is your doubt regarding this?
04-18-2016 05:08 PM
04-19-2016 04:45 PM
A 90 degree phase shift would work result in a cosine wave as you mentioned. I don't understand what is your concern in relation to how the output, it is going to be affected since the source signal is changing, but that is to be expected.
