03-21-2016 03:51 PM
I needed a power transformer with dual primary and dual secondary windings, but there was no such model in the database, so I created a hierarchical block utilizing two transformers with single primary and secondary wndings. The HB simulates correctly and I created a proper footprint in Ultiboard. However, I have problems exporting the new HB footprint to Ultiboard. If I try to assign the footprint while editing the HB, I get two transformers in the layout. If I don't assign any footprint while in the HB edit mode, exporting the netlist to Ultiboard results in no part in the layout.
I've tried a few different approaches without success. I'm using the Power Pro Edition version 10.1. Any ideas?
03-23-2016 09:25 AM
The best way is to simply draw your own schematic symbol, and link those pins to your footprint.
Use the 'create component' wizard and you'll see... it's only a few minutes work...
stressed user
03-28-2016 07:17 PM
Thank you stressed_user for your suggestion.
I did create a new schematic symbol using the Symbol Editor and assigned a previously created footprint to that symbol. That did allow me to forward annotate the schematic to Ultiboard with a proper footprint. The only downside was that I was no longer able to simulate the design in Multisim, as I could not get a proper working Spice model for the transformer with dual primary windings. Any ideas on where I could find or create a suitable model?
popman
03-30-2016 01:47 AM
Sorry,
I can't help you on this one, I'm not really a 'simulator'. I do most jobs straight on the board.
I would suggest you make two schematics, one for simulation, and one for your routing...
03-30-2016 10:18 AM
That's what I have been doing, but it would be nice if I could have one master file that could simulate and export to layout.
popman
