04-01-2011 10:43 PM - edited 04-01-2011 10:47 PM
Yes, this circuit is correct. However, if you work with Bode Plotter, the frequency metre is not necessary.
04-02-2011 03:52 AM
I have multisim 11 registered virsion.i want to show my output waveform on the Grapher. i dont have the grapher!!
how can i add it to my toolbar?
thanks
04-02-2011 04:05 AM
main menu View>>Grapher
04-02-2011 05:56 AM
the graphic is not in my main menu view.. how can can i include it to the list?
04-02-2011 05:58 AM
04-02-2011 08:29 AM
See Multisim Help:
Commands tab
Use the Commands tab in the Customize dialog box to add commands to menus and toolbars.
Complete the following steps to add a command to a menu or toolbar:
1.Make a selection in the Categories list.
2.Drag the desired command from the Commands list to the desired menu or toolbar. When a command is selected in the Command list, its description is displayed in the Description field.
3.Click Close when customizations are complete.
To remove a command from a menu or toolbar, right-click on it and select Delete from the context-sensitive menu that appears. The Customize dialog box must be open when you do this.
To change the position of a command that is in a menu or toolbar, drag it to its new location. The Customize dialog box must be open when you do this.
04-02-2011 10:15 AM
i got it. thanks
04-02-2011 09:35 PM
what is the difference in oscillation wave at point X and at point Y?
for my knowledge, the diodes block the distortion that caused by OP amp and if i show the waves at node X, that means i am showing distorted waves,but i did not see this in both circuit. both circuit showing exactly same waves with same amplitude and non distorted even if i bypass the diodes!!!!
kindly, i need advice and explanation.
