Multisim and Ultiboard
oscillator
Yes, this circuit is correct. However, if you work with Bode Plotter, the frequency metre is not necessary.
Message 11 of 18
(1,251 Views)
I have multisim 11 registered virsion.i want to show my output waveform on the Grapher. i dont have the grapher!!
how can i add it to my toolbar?
thanks
Message 12 of 18
(1,246 Views)
main menu View>>Grapher
Message 13 of 18
(1,244 Views)
the graphic is not in my main menu view.. how can can i include it to the list?
Message 14 of 18
(1,242 Views)
Message 15 of 18
(1,239 Views)
See Multisim Help:
Commands tab
Use the Commands tab in the Customize dialog box to add commands to menus and toolbars.
Complete the following steps to add a command to a menu or toolbar:
1.Make a selection in the Categories list.
2.Drag the desired command from the Commands list to the desired menu or toolbar. When a command is selected in the Command list, its description is displayed in the Description field.
3.Click Close when customizations are complete.
To remove a command from a menu or toolbar, right-click on it and select Delete from the context-sensitive menu that appears. The Customize dialog box must be open when you do this.
To change the position of a command that is in a menu or toolbar, drag it to its new location. The Customize dialog box must be open when you do this.
Message 16 of 18
(1,232 Views)
i got it. thanks
Message 17 of 18
(1,226 Views)
 what is the difference in oscillation wave at point X and at point Y?
for my knowledge, the diodes block the distortion that caused by OP amp and if i show the waves at node X, that means i am showing distorted waves,but i did not see this in both circuit. both circuit showing exactly same waves with same amplitude and non distorted even if i bypass the diodes!!!!
kindly, i need advice and explanation.
Message 18 of 18
(1,211 Views)
