NI TestStand Idea Exchange
MaximeR
Add plugin to Quick Drop for TestStand
Status: New
When you devevlop in TestStand, you may have some tools that you can use to automate some developments actions but it's not easy to share of use it in TestStand.
My best way is to customize my Tools menu but it's not user friendly.
Since you introduce the Quickdrop in TS2019, can we imainge that you can support addon to have access more easily to developpers tools ?
Maxime R.
  CLA - Certified LabVIEW Architect / Architecte LabVIEW Certifié
  CTA - Certified TestStand Architect / Architecte TestStand Certifié
2 Comments
Mr._Jim
I'm pretty sure I would use this, just as I have in LabVIEW. I have pre-programmed TestStand API routines that I use on occasion.
bienieck
Similar here: https://forums.ni.com/t5/NI-TestStand-Idea-Exchange/Add-Tools-to-Quick-Drop/idi-p/4103315
Michał Bieńkowski
CLA, CTA, CPI
