TS does not allow the ability to rename steps that are of the Flow Control type (i.e. If, Else, For, While, etc.). In a report, these generic names are then used, making it very difficult to know what condition the step was evaluating to determine whether to enter or continue within the flow control block. A step name would normally give the reader of a report some indication as to what is being tested or reported on. This is not the case for these step types.
For example, an "If" step that is determining whether a condition is met (and whether to enter into the subsequent steps within the flow control block) simply shows up in the report as:
Step | Status | Measurement | Units | Limits | ||
Low Limit | High Limit | Comparison Type | ||||
If {True} | Done |
There is no indication of what it evaluated to determine it was True, meaning someone reading the report has no idea what the purpose of the step is. As designer of the test, I can look through the sequence to determine exactly what it was doing, but a report is a useful tool to be able to show to someone not familiar with the test and allow them to be able to see what happened. A report gives the reader the history of the test. Without knowing what a step is for, a lot of the "story" being told by the report is either lost or becomes much harder to follow.
I would assume there is a reason as to why these step types are not able to be renamed, but I'm not familiar with what that would be. It would be nice to be able to modify, or at least add to, the step name so that the report gives some indication of what it was that it evaluated. If that is not possible, there should be a simple way to include the parameter/expression being evaluated with the step name in the report. This can be somewhat accomplished using other methods, such as the Additional Results of the Properties tab, but this is not intuitive or clean and I would think this behavior should actually be default, not something the user has to manually create and enable.
