There is no way to programmatically clear the Output Window in TestStand. It would be beneficial to be able to clear it through the API and through an expression function. The only way to clear it right now is manually. This benefit would allow developer's to configure the system to only see messages from their current run, only show one message at a time so you could iteratively overwrite it to show measurements changing for example, or many other benefits.
