There is often problems with cross-linking the wrong LabVIEW VI code modules. Why not automatically import VIs into TestStand from LabVIEW projects using the name of the LV project as a name extension for each VI in TestStand?
For example, if the name of the LV project is "Project 1.lvproj" and contains VIs named A.vi and B.VI, then these could easily be loaded into testStand as "A-Project 1.vi" and "B-Project 1.vi"?
Eugene
