* Why not include Configuration files, such as TestExec.ini by default in Deployment Utility?
* Also using default settings, nothing appears in the Start Menu/All Programs menu on the target machine. Why not have the main sequence file to be installed so that it appears in the Start Menu/All Programs menu on the target machine?
Eugene
We chose not to include this by default, but now there is a "From TestStand Configuration Directory" option on the source tab. If you check that box it will preselect the most relevant config files for you.
