But this is the TestStand Idea Exchange, not the LabVIEW IE. Therefore, not a duplicate.
But those arguments against this idea are still valid.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
TestStand supports negative array bounds though so this would not be possible without breaking backwards compatibility. Also, -1 is sometimes used for uninitialized index variables in which case a user might prefer to have teststand give an error to help them catch bugs in their code rather than have it give them the last element when that's not what they intended.
I think that (someone else might have to keep me honest here) TS is still missing reverse() as it pertains to arrays -- whether I can reverse a 1D array. If reverse() was implemented (also important because 50% of the time I sort an array it will come out backwards) then you could use positive indexes against reversed arrays (might be a little slower, but doable).
