NI TestStand Idea Exchange
MimiKLM
New feature request: Step Settings --> Module --> Reload VI prototype in all steps.
Status: Already Implemented
See Warren's post
It's a very likley to happen that during the test the one LV module is called more than one time. As well it is very likely to happen the during the development we have to modify the module itself by changing the input/output from the VI or the connector pattern of the VI. If we have to Reload VI Prototype in one or two instances it's fine but when the step is in more than two or three places it is very painfull to update all of them.
So, I'm proposing to extend the Step Settings-->Module menu by adding the button with action Reload VI prototype in all instances.
3 Comments
warren_scott
How is what you are proposing different from Tools >> Update VI Calls?
PhillipBrooks
http://digital.ni.com/public.nsf/allkb/D7CB87B8EE52E7978625758400762D2D
Now is the right time to use %^<%Y-%m-%dT%H:%M:%S%3uZ>T
If you don't hate time zones, you're not a real programmer.
"You are what you don't automate"
Inplaceness is synonymous with insidiousness
WireWeaver
Status changed to: Already Implemented
See Warren's post
