The concept of TestStand Environments was introduced in TestStand 2016 and allows you to define multiple configurations on a single test station or development PC. It would be nice if there was an option to link a sequence file to a specific environment, similar to how you can set a sequence file to "Require Specific Model" In the Advanced tab of the Sequence File Properties. When a sequence file is loaded, the engine could check to see if the required environment matches the current environment and:
It would be nice to choose the behavior when a required environment doesn't match.
If anyone has other thoughts or use cases, please share below.
-Trent
