NI TestStand Idea Exchange
Pete_Cooper@Genie_Industries
Provide expression browsers for the FTP Step Type for setting paths
Status: New
Provide capability to allow set a property that contains the full path of the file to be downloaded/uploaded via an expression browser. When running my tests with my sequence file I won't know my filename/pathname until the test is completed. Provide an expression browser for the remote path and the local path so I can dynamically set the property of the path at the end of the test.
3 Comments
Provide capability to allow set a property that contains the full path of the file to be downloaded/uploaded via an expression browser. When running my tests with my sequence file I won't know my filename/pathname until the test is completed. Provide an expression browser for the remote path and the local path so I can dynamcially set the property of the path at the end of the test.
denis76
+1
denis76
Work around. Use pre-expression. Example:
