NI TestStand Idea Exchange
Sam_Sharp
Remove Key Focus from Database Options Dialog (allowing the use of Enter to create line breaks)
Status: Completed
Fixed in TestStand 2017 under ID 669336
The Database Options dialog in TestStand 2013 and 2016SP1 (the versions I have tried) have the key focus set to the 'OK' button. Pressing the 'Enter' key at any point while navigating that dialog will close it and not save the changes.
This becomes very frustrating when editing the 'Command Text' of a database statement as you might want to insert line breaks to make editing/reading the statement easier.
I have had this happen at least 10 times already today and is very frustrating and is only a very minor change to the Database Options dialog.
Hopefully we could get it as a patch?
(blog)
2 Comments
Scott_Richardson
Status changed to: Under Consideration
Sam, we will look at fixing this, thanks for point it out.
Scott Richardson
https://testeract.com
Scott_Richardson
Status changed to: Completed
Scott Richardson
