In our Company also hardware developer creates testsequences in teststand, so it would be nice, if there could be a small user interface to configure the values of the parameters for a subsequence.
The solution could be, if they drag and drop a sequence into their main testsequence, a user interface pops up to configure the parameters for this subsequence. So it would be possible to restrict the values with a drop down menu or Radio Buttons or to give some graphical help to choose the right values.
Or maybe i could create something similar to the IVI sequences, where i can click on a button and a small editor window is opened.
MOBA-User,
Thanks for clarifying - i was assuming based on your description that you wanted an Edit UI for some kind of subsequence, not just a step (hence linking to the other post). You can accomplish that today via the workarounds listed in the link.
