Create TempReport at the End of the test
Hi everyone,
my MainSequence generates a TestReport, the one i want is the TempReport. But is it possible that the Report is generated at the end of the test and not just after clicking the OK-Button on the UUT Result-window?
The pdf-generation of the report is unfortunately not the perfect format for me so i want to use the file of tempreport because it has the right format.
Thanks everyone
Tobi
Message 1 of 9
(1,796 Views)
Hi Tobi,
what do you mean by TempReport?
Oli
Message 2 of 9
(1,778 Views)
Hi Oli,
It creates the TempReport AFTER running my test run. But only when I confirm with ok and then no longer want a new run. It's the UUT Report tr5expand.
But I would like it to create the TempReport at the end of/during the test run like the PDF report.
I hope you know what i mean.
Thats the TempReport, which is also stored as a temporary .html and its better than the generated PDF because you can expand and collapse the results:
Cheers
Tobi
Message 3 of 9
(1,739 Views)
Or I would now have a different procedure and would execute the mainsequence with the TestStand Operator Interface. But here it does not create a report for me at all. Neither one in .xml form that is always created nor the TempReport that I would like to have.
Why is that so? Isn't there a way to create Reports via the Operator Interface?
Message 4 of 9
(1,727 Views)
OK, let's clarify some stuff regarding TesStand wording.
If you activate Result Processing
the TestStand ProcessModel takes care, that Results are written to file after each UUT executes.
What you see once you Stop Testing when using the Test UUTs entry point is the report of the last UUT tested
Note: you have some options available to configure Report Generation: e.g. to create a file for each UUT each or to append all reports to a single file
Message 5 of 9
(1,722 Views)
Yes I know these options. But if im not wrong its only possible to configure the .xml-report.
But the Report i want is the .html-TempReport which is generated right after the test. It is the report which can also be generated as a PDF but in the PDF there is the function of expand/collapse not possible.
Long story short: I try to generate the .html-Report (not after testing) at the time when the PDF is generated (at the end of the test). Is that possible?
That is generated at the end of the test:
And this is generated after the test:
 The content of the file (pdf - html) is the same but i want the the .html best at the end of the test (not after it), because of the functions (expand/collapse).
Message 6 of 9
(1,710 Views)
Sorry.... need to ask again
after test == UUT finished
end of the test == all UUTs finished
Message 7 of 9
(1,681 Views)
I only want to test 1 UUT so just 1 runtrough.
I hope the following picture makes it clear.
Message 8 of 9
(1,661 Views)
Thanks for the clarification!
From what I see, the TempReport.xml is a temporary file which is used for generation / rendering of the PDF.
The handling of this file is executed by the NI ReportGenerator.
There is very little information out there on that one...
BTW.... Have you already tried to set up an XML Report with similar contents compared to TempReport?
Message 9 of 9
(1,653 Views)
