02-18-2010 11:57 AM
My deployment builds were hanging. Killing LV twice would allow them to run to completion. Build would work fine without an installer. So I tried just building an installer and I get these results:
Starting a log for the deployment.
Starting Analysis
Finished Analysis
Building...
12:50 PM
The build process is done.
12:50 PM
Aborted
The build contains no files or components.
02-19-2010 05:23 PM
jvh,
The output you see is expected if you do not select any files, drivers, or components as a part of the installer. In order to successfully create an installer you it must contain some files that you want to distribute, or the TestStand Engine along with the drivers & components necessary to run the deployed files.
02-20-2010 07:08 AM
Right you are. Was going thru scenarios suggested by Austin help desk.
thanks,
jh
