Error results in UUT Test Pass
When running a test sequence in Operator mode, if a step fails for "Error, visa[...]" or "Error, LabView[...]", the test will exit and in the test result file UUT Result shows the error. However we send the result to our own database and it is showing these as a TEST_PASS, the data is coming from "FileGlobals.TestResult".
My Main Sequence Cleanup is as follows.
Any help greatly appreciated.
LABOR OMNIA VINCIT
Message 1 of 8
(498 Views)
What is your error handling strategy? Terminate on error?
Message 2 of 8
(463 Views)
I have three levels of login setup, with operator mode when this happened they only had the option to terminate on error.
LABOR OMNIA VINCIT
Message 3 of 8
(455 Views)
Can you describe, how the FileGlobal Value is logged into the database?
Message 4 of 8
(443 Views)
At the end of main sequence the following cleanup is run...
I then have a PostUUT sequence that calls an executable, the exe sends the test result file to our database along with the result from Cleanup - str(FileGlobals.TestResult) which will be either TEST_PASS, TEST_WARN, or TEST_FAIL.
LABOR OMNIA VINCIT
Message 5 of 8
(428 Views)
If you are sure, the data is passed correctly from TestStand to the executable, the issue can probably be found somewhere between the exe and the database.
Is there any conversion involved form string to enum? Maybe sth goes wrong there
Message 6 of 8
(410 Views)
Thanks for your response, but I am sure it is happening prior to this as all that happens in this step is the test status is retrieved from TestStand and passed to the database, the test status is set during the cleanup. I believe it is being incorrectly set when a test is terminated.
LABOR OMNIA VINCIT
Message 7 of 8
(358 Views)
When trying to debug this, make sure to have SeqEdit configured correctly
Message 8 of 8
(356 Views)
