04-09-2015 06:32 PM
Tools >> Import/Export Properties looks promising but I never get the acual expression no matter what I select.
04-09-2015 11:22 PM
You can search within TestStand. Why do you need ot export them?
Go to Edit>>Find/Replace In Files... Then you can set up the filter however you'd like.
04-10-2015 12:20 AM
Good point, but I want to write software that parses a file with ALL the expression. And I just figured out how to do it; you can save the file as XML. That's not where it should logically be, in the File >> Save As... place, but a sequence file properties dialog box that I don't have the exact name right in front of me.
04-11-2015 01:24 PM
You can also go to Tools>>Sequence File Documentation. This will print to either text or html. This way you don't have to change the format of your file as you described.
Hope this helps,
04-14-2015 12:42 PM
This Tools>>Sequence File Documentation is certainly much faster and I'm glad I learned about it; but it doesn't capture the information I want which is the contents of expressions in a Numeric Limit Test.
Exporting the sequence file as XML gets absolutely everything including those expressions.
12-10-2024 02:19 AM
Hi bmihura
Thank for the helpful explanation,
by the way, I'd like to use it on command line using Ni.exe blabla ~SEQ file with option ".csv" or ".xml" like format setting.
Have you been trying this way or any methodology you heard about ?
If yes, please let me know how to opreate it.
Appreciate it.
12-10-2024 02:41 AM
I've never heard about the command line approach, but I know that TestStand's executable is "SeqEdit.exe" Doing an Internet search on "SeqEdit.exe command line" is probably the best way to keep looking.
12-10-2024 03:05 AM - edited 12-10-2024 03:47 AM
yes exactly matched what I want to do for command-line approach.
As you mentioned, I found SeqEdit.exe in Bin sub-folder of TestStand.
also found interesting command "SequenceFileConverter"..
it looks like, possible to support command line processing.
anyway, thanks for helpful comment.
12-10-2024 04:54 AM
Hello, bmihura_esa
finally i found some command-lie methodology to convert from "SEQ-binary" to "SEQ-XML", this could be readable in terminal.
thanks for your insight, seqedit.. was the triggering point to me to think about BIN folder with how to use..
Thanks, Have a great day !! 🙂
Command-Line Usage
SequenceFileConverter.exe [-Help] [-Recursive] [-Quiet] [-UpdateVersion] [-Unlock:<PasswordList>] [-Format:<Format>] [-Protect:<Mode>:<Password>] <file or directory path> [-env <environment path>]
Format:<Format>—Converts all files to the specified format. Possible values for <Format> are binary, INI, and XML.
