02-21-2010 01:37 PM
Hi I have a problem with loading a container of data using propery loader.
In sequence file I declared a new type. The container AA contains a number BB and an array of numbers CC.
In sequence I create the instance CCC which is array of AA type.
However, I couldn't load data from the file into FileGlobals CCC variable.
Probably there is a problem with the syntax.
Could anyone help me with that?
02-22-2010 01:00 AM
The easiest way to get the syntax correct is to use the Import/Export Tool.
I would do this for you from your sequencefile but do not have access to TestStand (at the right version) right now.
But it is and easy process.
Ray
02-22-2010 01:43 AM
Dont you have to define the HBound?
regards
Ray Farmer
02-22-2010 05:01 AM
Yes, it looks like a syntax problem.
To test the problem I created a new type in the sequence. I set the defaults values. Then I created a FileGlobals variable (QQQ). Then I exported data using Import/Export function to receive syntax.So, it seems to be not easy thing as Ray said. At least no easy to read.
I'm wondering is there more easy to read syntax to load properties?
02-22-2010 05:22 AM
