NI TestStand
Set Post Expression of Step (Not Next or Previous Step)
Is it possible to set the post expression of a step, which is not the Next or Previous step?
I know this is possible
RunState.NextStep.PostExpression = "Enter Post Expression Here"
 I am looking for something like
RunState.Step("StepID").PostExpression = "Enter Post Expression Here"
Does anyone know if there's a way to accomplish something to that effect?
Thanks!
(4,662 Views)
Accepted by christopherdean
RunState.Sequence.GetStepByUniqueId("ID").PostExpression = "Blah"
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,652 Views)
Thank You!
I didn't realize I should be looking in RunState.Sequence
I think I'm going to use GetStepByName now that I know that exists, and I can paramterize that to be an intuitive control.
(4,648 Views)
If you plan on executing the sequence in multiple threads at once, it's best not to make a self-modifying sequence like this since many of the step setting properties like PostExpression are shared between all threads.
-Doug
(4,611 Views)
Doug,
Thanks for the heads up.
The step will only change once, at the start of the routine, if at all.  I am only interested in setting up the elements of an array which I write to my datalog, which does not change very often, and will not change once the routine is running.
(4,573 Views)
