NI TestStand
Show current loop iteration
Hi Everyone,
Is there a way to show current loop iteration, instead of the text “looping” when TestStand is running, as shown on attached picture. Thanks,
tstand
(5,072 Views)
Accepted by topic author tstand
Use a FOR loop instead.  And looking at your code, you should be using a FOR loop anyways.  It would cut down your number of steps.
GCentral
(5,054 Views)
Also, I am running main sequence in a loop (over 50 times).  Is there a way to display status of main sequence pass/fail results for each run, so I could count how many times pass/fails?
(5,044 Views)
I would just keep those in variables and you can watch the variables.
GCentral
(5,041 Views)
Another idea is that you can just place down a action step using the none adapter.  Change the Status expression to evaluate to a string.  For instance Str(Locals.PngCnt).
As the test executes you can see the Status column display the values.  This is especially nice to view variables without having to pause the execution.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,032 Views)
Thanks crossrulz and jigg.
tstand
(5,023 Views)
