02-16-2015 08:02 PM
Hi Everyone,
Is there a way to show current loop iteration, instead of the text “looping” when TestStand is running, as shown on attached picture. Thanks,
tstand
02-17-2015 04:45 AM
Use a FOR loop instead. And looking at your code, you should be using a FOR loop anyways. It would cut down your number of steps.
02-17-2015 11:17 AM
Thanks crossrulz,
Also, I am running main sequence in a loop (over 50 times). Is there a way to display status of main sequence pass/fail results for each run, so I could count how many times pass/fails?
02-17-2015 11:23 AM
I would just keep those in variables and you can watch the variables.
02-17-2015 12:14 PM
Another idea is that you can just place down a action step using the none adapter. Change the Status expression to evaluate to a string. For instance Str(Locals.PngCnt).
As the test executes you can see the Status column display the values. This is especially nice to view variables without having to pause the execution.
02-17-2015 01:31 PM
Thanks crossrulz and jigg.
tstand
