TestStand Base Install Location Wrong
Hello All
I'm doing a TestStand deployment. The problem is when I install the deployment on a Production PC, the install location is not what I specified in the Deployment Utility. Below are my Installer Options. And the second picture is where the installation takes place after running Setup.exe.
This is the same location as where my .seq and .vi files are stored. So it Installes over itself.
What am I missing?
Marinus
(650 Views)
Although you have defined the default file location, the files properties on the Distributed Files need to reference the base location.
If you share an image of the Distributed Files tab for any of the files that you think are incorrectly installed, we can better understand how you are configuring files in the installer.
Scott Richardson
https://testeract.com
(631 Views)
Hello Scott
Here are my Distribution Files. I included the Installer Options again for comparison.
Thanx for helping.
Marinus
(616 Views)
In the above image you are selecting the Personal Directory (C:\Users\<user>\Documents) as where that file is going. If you wish to install a file to the default location for the installer, you must select "Installation Directory". You can refer to these help topics for more information: Distributed Files Tab, specifically Installation Destination control, and Installation Destination Options.
Scott Richardson
(588 Views)
