error code 17301
When I try to compare to similar .seq files using the diff sequence option I get an error:
Index out of range
Error code:-17301
Is this because the sequence files are not similar enough? The sequences themselves are similar, but there are different menus and sequence calls. Does anyone know why I'm getting this error?
(5,011 Views)
Accepted by Suraj34
What version of TestStand are you using? Can you try diffing the files in a more recent version of TestStand if you are not currently using the most recent version?
-Doug
(5,003 Views)
Accepted by Suraj34
Doug,
     Thank you for your reply. I did try the diff seq option on Test Stand 5/6 and it worked. I was even able to generate a XML report of all the differences.
    Before I tried it on Test Stand 3.1 and I got the error. Interesting enough both the sequence files were made using 3.1.
Thanks for the tip,
Suraj
(4,989 Views)
Accepted by Suraj34
@Suraj34 wrote:
Doug,
Thanks for the tip,
Suraj
No problem. A brand new differ was introduced with TestStand 2010 (4.5) with many improvements.
-Doug
(4,966 Views)
