01-26-2015 01:46 AM
When I try to compare to similar .seq files using the diff sequence option I get an error:
Index out of range
Error code:-17301
Is this because the sequence files are not similar enough? The sequences themselves are similar, but there are different menus and sequence calls. Does anyone know why I'm getting this error?
Solved! Go to Solution.
01-26-2015 09:20 AM
What version of TestStand are you using? Can you try diffing the files in a more recent version of TestStand if you are not currently using the most recent version?
-Doug
01-26-2015 03:58 PM
Doug,
Thank you for your reply. I did try the diff seq option on Test Stand 5/6 and it worked. I was even able to generate a XML report of all the differences.
Before I tried it on Test Stand 3.1 and I got the error. Interesting enough both the sequence files were made using 3.1.
Thanks for the tip,
Suraj
01-27-2015 08:36 AM
@Suraj34 wrote:
Doug,
Thanks for the tip,
Suraj
No problem. A brand new differ was introduced with TestStand 2010 (4.5) with many improvements.
-Doug
