05-12-2022 03:58 AM
If I call a vi containing 'report generating' functions in teststand there is no problem when using the development adapter, but when I use the runtime adapter I got the error 1498.
I then created a 'Source Distribution' lib, knowing that every sub vi's need to be 'Preserve compiled code', but now I get the error 1448 in both development and runtime adapter.
I use teststand and labview 2016(including report toolkit) on a windows 10 pc.
I have included the project how I create the source distribution and also the source distribution build.
Error 1489:
Error 1448:
05-12-2022 06:56 AM
I think I found a solution, think it's more a work around.
Since the report components load dynamically, I removed the abstract class.
Next made a source distribution and now it works.
It's seems that the report toolkit does not work directly in teststand which is a bit sad I think.
Maybe somebody knows a different way to use the functions in teststand like in the example.
Picture below show the work functions:
