programmatically edit search directories
I would like to know if there is any way using TestStand API to programmatically do the following:
- Get the path value of the entire search directories
- Get the path value of selected index of the search directories
- Insert/Add a new search directory
- Remove one search directory
Thanks for your help and have a nice day
(793 Views)
Check the attached example.
Michał Bieńkowski
CLA, CTA, CPI
(749 Views)
