NI TestStand
saving in original version
I am running Teststand 2016, but out in the field we have some much older systems. I want to edit these sequence files here and save them for the original version. My probem is I do not know that version. How do I read the version of teststand that a sequence file was created for?
Is there any way of saving as original, without doing the save as and manually selecting the version?
Thanks.
David
(1,878 Views)
Accepted by David_Stevenson
If you open the file and choose 'Edit»Diff Against Saved Version' before you save it, it'll tell you what version the file format is on disk. Another option is just to open the original sequence file in notepad and the version should be visible.
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(1,652 Views)
