02-17-2010 03:02 PM
02-17-2010 10:34 PM
If you step is within the main sequence of the sequence file, then the following precondition should work
RunState.Caller.RunState.Sequence.Main["PreUUT Callback"].Result.Status=="Passed"
02-20-2010 04:09 PM
Pass back the ContinueTesting boolean of the PreUUT callback as False and the MainSequence callback will be skipped - also however, testing will be stopped too.
