what property can force the MainSequence to be skipped if a step in the PreUUT sequence fails
If you step is within the main sequence of the sequence file, then the following precondition should work
RunState.Caller.RunState.Sequence.Main["PreUUT Callback"].Result.Status=="Passed"
(3,206 Views)
Accepted by mike_22
Pass back the ContinueTesting boolean of the PreUUT callback as False and the MainSequence callback will be skipped - also however, testing will be stopped too.
(3,169 Views)
