PXI and Instrumentation Idea Exchange
christian1996
NI scope Trigger
Status: New
Problem: If you want to acquire data with a measuring loop you have to send a trigger in each of the loops. I became this problem because I wanted to measure over a long period.
Possible Solution: Decouple the Trigger from the Fetch Measurment. So the programm waits on the trigger at the configuration on the trigger.
1 Comment
AristosQueue (NI)
NI Employee (retired)
"a measuring loop" implies one loop, but then you mention "each of the loops" implying multiple parallel loops. Can you please clarify your request? An image showing the problem code (and a second image showing what you'd like to see) would help significantly in understanding what you are requesting.
