06-01-2017 09:52 AM
I have a PXI-1045 chassis that has a different front rackmount kit that what NI currently sells. What is the part number of this rackmount kit? And how can I acquire more? Thanks!
06-01-2017 10:01 AM
I meant to say "than NI currently sells."
I cannot find this rackmount kit on NI's website....which is why I am posting here.
06-02-2017 12:58 PM
Howdy,
Did you purchase this from NI originally? I was looking through our old front rack mount kits and even those have different hole patterns than the ones you are showing. Is there any reason you are hesitant to use the one on NI's website that you found?
Thanks!
Ryan M
06-02-2017 01:04 PM
I was just trying to help identify what rackmount kit I have. A part number mostly. I didnt purchase them from NI. They came attached to a PXI-1045 we got used from someone.
So are you saying that NI did not make these rackmount kits?
They have the powdercoat as if they were made by NI. They are also well made....which NI is known for.
06-05-2017 01:24 PM
NI's rack mount kits will have the part number stamped somewhere on them usually, so everything I've seen so far points to it being an unknown manufacturer. I'd try to see if you can find out where the person you got the chassis from acquired the kit.
