Execute a VI only once on an event becoming true the first time
I am using CompacDAQ hardware for a press monitoring application.  I have an absolute multi-turn encoder wired to a 9435 and I want to trigger a measurement and storage VI once whenever the encoder is greater than a certain angle (e.g. 270 degrees).  The trouble is, I cannot seem to make the result of a boolean comparision only execute one (like a rising edge).  This is known as one-shot functionality in the PLC world.  How can I implement this in the Labview environment?
Mike Voll
(3,030 Views)
Look into using Shift Registers on your loop and using the Greater Than comparison on your Boolean condition to trigger your operation.
Message Edited by Christian L on 05-15-2009 09:48 AM
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(3,010 Views)
