how to add or edit waveform data in a CTL Type Def file?
Accepted by JesseBuck
Hi JY
That is a great answer to my question.  Now that I see how to make my original plan work in sufficient detail, I wanted to also ask if there is a more natural LabVIEW way of adding a new sound to this workshop training example?
Jesse
PS,
A challenge that I sometimes face with LabVIEW is that I will figure out a logical approach to implementing some kind of function that will turn out to be clunky, and most often there is a new vi to be discovered (somewhere) that does the optimal job of that particular function
Message 11 of 13
(1,391 Views)
Hi Jesse,
This thread has some alternate ideas about how to import data from a spreadsheet into an array constant. It's pretty old (2001!), but the general ideas described there are likely still valid, even if the VIs have changed names since.
On a side note, I hadn't really considered doing that until you asked- it sounds like it'd be a much easier way to create large arrays in the future. Thanks for asking such a good question!
Kathryn K.
Technical Support Engineer
http://ni.com/support
Message 12 of 13
(1,384 Views)
Hi Kathryn,
Thanks for the link to the 2001 post.  I think that shows the LabVIEW way to create an array constant is to write a vi that fills up an array, turn the array into a constant, then delete the rest of the vi, leaving the constant as  a new entity.  I hadn't thought of that!
Jesse
Message 13 of 13
(1,365 Views)
