11-01-2016 05:59 PM
Hi NI Community,
Not sure if this is the right place to start. But, someone must have had a similar issue.
We are using C# to talk to our NI 6323 board.
We have two analog inputs that need to be read. (No problem setting that up.)
Here are the inputs:
static private Task SensorInput; //needs to be read 10,000 per second
static private Task InputVoltage; //needs input every 2 seconds
reader = new AnalogMultiChannelReader(SensorInput.Stream);
data = reader.ReadWaveform(10,000);
Trouble is we need the "InputVoltage" to be read every two seconds and it sometimes gets "locked out" by the 10,000 samples per second stream going on for the "SensorInput"
Is there a way to raise the "priority" of the InputVoltage task so that it always reads a value. Often we only get the exception NationalInstruments.DAQmx.DaqException: The specified resource is reserved. The operation could not be completed as specified.
Brian
11-02-2016 11:49 AM
Hi BCES,
It's not necessarily a priority issue, you can just run one task at the time. For a quick workaround, I recommend you to get both channels inside the same task with a larger acquisition rate and filter the data simulating it has been gotten at the rate you need.
You also can stop the task, run the other one, stop it and start the first one again. Take a look at this links they might help you to understand how to improve your program in the future
http://www.ni.com/product-documentation/2835/en/#toc7
http://zone.ni.com/reference/en-XX/help/370466AC-01/mxcncpts/taskstatemodel/
