Signal Conditioning
Filtering signal from AE sensor to replace Kistler Piezotron Coupler Type 5125B
Hi there,
I am using two Kistler Acoustic Emission Sensors Type 8152B111 to detect fracture in bone. I am using one Kistler Piezotron Coupler Type 5125B to filter the signal output from one sensor but for the other I need to filter the signal using LabView. I need to know if this is possible please, and a rough guide on how to go about this.
The amplifier is able to filter the signal using one high pass (50kHz) and one low pass (900kHz) filter. A butterworth filter is required and we also need a gain of 10 or 100.
Below is a list of the products we purchased a while ago:
  • NI PXIe-1082 (Part no. 780321-01) Express chassis with AC
  • NI PXIe-8135 (Part no. 782450-04) 2.3GHz Quad-core express controller
  • NI PXIe-6356 (Part no. 781053-01) Simultaneous X series Data Acquisition
  • NI PXIe-4331 (Part no. 781345-01) Bridge input module
  • NI PXIe-4492 (Part no. 781490-01) BNC analogue input module
  • NI TB 4330 (Part no. 781437-01) Terminal Block
I have attached the specification sheet for the coupler and tha for the acoustic sensor also, to clarify.
(7,195 Views)
Hi ClodaghD
We have the possibility to use different VIs, in our case I will attach some links that will be useful for you:
http://digital.ni.com/public.nsf/allkb/A466D72090293B438625727D00038688
http://www.ni.com/white-paper/3237/en/
Regards
(7,163 Views)
Your sensors need a current drive supply, so for one sensor you are using the 5125, but do you already have a constant current source for your other sensor?
Don't just hook it up to a voltage supply, you can burn up your sensor!
If you want to use both sensors simoultaniously AND you need to have (well, ... about) equal transferfunctions (gain, filter) , you will nedd to do channel calbrations anyway to do a correction,
I asssume you do the analyses in the frequncy domain, so there is the way to do the correctons.
If you just want to use both sensors for a task, a Q&D solution is possible.. but a professional solution would be to use two identical conditioner.
the cheap Q&D solution includes soldering your own driver circuit 😉
What do you NEED to do?
Greetings from Germany
Henrik
LV since v3.1
(7,136 Views)
