04-30-2024 07:16 PM
Our team has a relatively new Roborio 2.0 that was working well until this competition season. The 5V power rail is now not working, and the status lights are blinking continuously. We vacuumed out any possible metal shavings that could exist, but the issue is persisting. Requesting a replacement Rio.
On another note, we have another Rio 2.0 that has the known issue regarding the broken SD Card Slot and are requesting a replacement for that one as well.
05-02-2024 04:06 PM
Hi nexish,
I hope you´re doing great!
This is Nahuel from NI, to double-check, have we tried the following steps for the RoboRIO 2.0 with the flashing STATUS-led? If so, do we still have the same STATUS-led behavior after performing them?
Have a great day!
05-23-2024 08:27 PM
Hi Nahuel,
We did the steps described in your instructions, however the issue is persisting. Are there any other things that we should do or is this grounds to replace the RIO. We also have the problem where the SD card will not click into it's slot on another of our RIOs and would like to replace that one as well.
Thanks!
