USRP Software Radio
DPDK installation
I am working with USRP X440 and I am trying to enable DPDK. I have some problems with the installation process.
I have done the command:
sudo apt install dpdk dpdk-dev
 I am installing dpdk 23.11 and use Mellanox ConnectX5, do I still need to ran
CONFIG_RTE_BUILD_SHARED_LIB=y
CONFIG_RTE_LIBRTE_MLX5_PMD=y
If I have to, where can I configure this?
Also, to perform NIC configuration, where can I find the UHD configuration file? Why I do not find it in /etc/uhd/uhd.conf.
I ran a GNU Radio program with arguments use_dpdk=1, but get this error:
Is it because the NIC configuration or other settings?
Thank you very much.
Message 1 of 1
(173 Views)
