05-02-2016 07:48 PM
For the powers that be, where are the help docs for the USRP & USRP related blocks (host side & lvfpga blocks) ? Help is greyed out in the menus. If they came with the driver they must be bundled in with something not obvious & didnt install. Where are they ?
BTW, I'm using NU-USRP 15.00.
Thank you.
05-03-2016 11:42 AM
apchar,
Have you tried going to Help->NI USRP Help ?
05-03-2016 06:07 PM
Thank you muffin. I guess I'm too accustomed to right-click->Help on the blocks. But these docs only cover host side blocks. There's little mention of lvfpga usrp blocks, like the many register bus setup blocks, DDC, DUC, etc.
05-04-2016 09:24 AM
apchar,
Try using context help on the USRP RIO driver VIs. Either click the "?" in the top right corner of the block diagram, or press Ctl-H, and hover over the USRP RIO VIs. You should see additional help documentation.
