USRP Software Radio
there are no help screens for usrp blocks
For the powers that be, where are the help docs for the USRP & USRP related blocks (host side & lvfpga blocks) ? Help is greyed out in the menus. If they came with the driver they must be bundled in with something not obvious & didnt install. Where are they ?
BTW, I'm using NU-USRP 15.00.
Thank you.
(4,328 Views)
apchar,
Have you tried going to Help->NI USRP Help ?
(4,314 Views)
Thank you muffin. I guess I'm too accustomed to right-click->Help on the blocks. But these docs only cover host side blocks. There's little mention of lvfpga usrp blocks, like the many register bus setup blocks, DDC, DUC, etc.
(4,303 Views)
Accepted by apchar
apchar,
Try using context help on the USRP RIO driver VIs. Either click the "?" in the top right corner of the block diagram, or press Ctl-H, and hover over the USRP RIO VIs. You should see additional help documentation.
(4,291 Views)
