DASYLab
Worksheet corrupting areas
I'm not sure how to explain this, but I am creating a new project and have been adding, deleting, and moving Modules in my Worksheet.  Now I have areas in my worksheet that act like there is something in that spot and will not allow a connection (wire) to run through the spot or allow a module to move to that spot.  Is there a way to clean up a worksheet?  At one time my project got locked up and would not respond and I had to have Windows shut it down.  This could have also caused the problem.  Any ideas on how to fix this?  I'm using DasyLab 13.0.
Message 1 of 8
(5,974 Views)
Stop. Close DASYLab.
Send me the worksheet. cj.butler@ni.com
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 2 of 8
(5,973 Views)
Hi Craig,
I have sometimes the same problem...
Try this:
-save your corruted worsheet in .DSA format
-open the .DSA worksheet and save it in .DSB format
The new .DSB worksheet should be "clean"... Smiley Happy
Frédéric Miqueau
MD Electronic, France
http://www.mdelectronic.fr
French Dasylab Forum : http://www.dasylab-forum.de/forum/index.php?showforum=43
Message 3 of 8
(5,913 Views)
Thanks for the tip.  I can try that if it happens again.  CJ already fixed it for me this time.
Message 4 of 8
(5,910 Views)
Ok Craig, you're welcome!
And how CJ fixed this problem???
Frédéric Miqueau
Message 5 of 8
(5,901 Views)
Just to close this out.... in some cases, I can repair corrupted worksheets.
Contact me via email or private message with a copy of the worksheet.
Message 6 of 8
(5,721 Views)
Can anyone provide a solution to this issue? I attempted the (DSB to DSA to DSB solution and I still have the area corruption in my workspace.
Message 7 of 8
(64 Views)
I have been same problems with some worksheet. It would be nice if someone would have solution for that.
br Mika
Message 8 of 8
(46 Views)
