Basically what I am looking for is something similar to this (except for DQMH)
https://forums.ni.com/t5/Actor-Framework-Documents/Actor-Framework-Sequence-Diagram-Parser/ta-p/3536...
It allows you to generate a trace with DETT and then use that as the basis for a sequence diagram.
A couple use cases:
1. You inherit a project that doesn't have any sequence diagrams. It would be nice to run this and see which modules launch which and how they communicate.
2. Troubleshooting - Things are supposed to happen in a certain order, but aren't working
3. Generating documentation - Let's say you didn't start by writing a sequence diagram, but now want to document the order things happen in.
I think this compliments the static diagrams in Anti-doc. Anti-doc clearly shows who sends broadcasts/requests to who, but doesn't show anything about timing.
@Olivier I think this would be a cool addition to Anti-Doc. It obviously couldn't generate the traces, but if you had a few, you could probably figure out how to point to them and include them. And maybe Anti-doc doesn't even run the tool on the traces. Maybe you run that seperately and then have antidoc render the resulting plant uml?
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at
sasworkshops.com/blog
So far, I'm declining your suggestion because, in any case, if a tool is going to be released in the future, it will not be part of the framework itself.
@Taggart, thank you again for your help and your time writing down this suggestion.
