Here's something I've been running into lately (for whatever reason hadn't done a ton with cloneable until now). I'm sure someone else must be as annoyed by this as I am.
Why do all the cloneable broadcast event VIs take a module ID and not a module admin object? Is there ever a reason where I would want to use a different module ID rather than the current one? I can't think of any, but maybe I am just not that imaginative.
Everywhere I drop a broadcast I have to also drop a property node and pull off the Module ID, why not just incorporate that into the broadcast VI?
By the framework not including that it requires extra effort on my part to wire it all up and it clutters my block diagram with property nodes that don't really add anything.
I'm sure there is probably some reason it was done this way. What use case am I missing where I would want to use a different module ID? and if there is a use case for that, I'm assuming it is an infrequent or minority use case. Is there some way we could make the primary use case the default (ie use the current module ID) without requiring all these extra property nodes, while still maintaining the ability to use a different module ID if needed?
Not sure if there is a way to do this and also make it backwards compatible? Maybe leave the existing broadcast vis as is and mark them as deprecated or something and add a wrapper that takes the module admin and then calls the 'deprecated' VI.
All I know is that there has to be a better way than dropping a property node every time or me manually creating a wrapper for every broadcast.
How does anyone else currently solve this problem?
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at
sasworkshops.com/blog
Hey Sam, thank you so much for your trust in DQMH and for taking time out of your day to share your idea with us.
You can place a property node for the Module Admin class outside the error structure and wire in the Module ID.
So, we decline this request, at least for the next DQMH version.
Again, thank you for your input; it is most appreciated. Please keep those ideas coming!
